TwinTurbo.NET: Nissan 300ZX forum - That's a shame. At least you'll have a definitive idea of
SirpriZ
on May 21, 2019 at 7:46 PM
Update
posted by BannonZ
on May 21, 2019 at 03:59 PM
your problem. And thanks for the follow up. Good luck
Starting issue: Continued
BannonZ
09:58:50 05/11/19
More parts replaced
BannonZ
10:23:36 05/11/19
Fuel pump controller unit?
FrozTTy
11:02:40 05/11/19
hmm
BannonZ
11:32:09 05/11/19
Did you bypass the FPCM? (n/m)
FrozTTy
09:35:28 05/14/19
Not yet. (n/m)
BannonZ
11:45:22 05/15/19
Re: Fuel pump controller unit?
Metacom
16:07:09 05/11/19
Yes
BannonZ
19:24:48 05/11/19
Check this thread out
Cjw3
11:39:57 05/11/19
Definitely has similarities. It hasn't been more than 50 f
BannonZ
13:12:55 05/11/19
Re: Definitely has similarities. It hasn't been more than 50 f
Cjw3
14:07:42 05/11/19
Re: Starting issue: Continued
MLPS300ZX
21:29:07 05/12/19
Re: Re: Starting issue: Continued
MLPS300ZX
21:34:28 05/12/19
Where is this valve located? (n/m)
FrozTTy
08:31:18 05/13/19
This one?
BannonZ
11:49:27 05/13/19
Yes that, but I'm wondering where it is on the car... (n/m)
FrozTTy
15:37:09 05/13/19
That's it. It's on TTs only. I have a fuel pressure gauge...
MLPS300ZX
14:45:40 05/13/19
I did a fuel pressure test today.
BannonZ
14:57:57 05/13/19
Is your chip setup for dual or single pop?
MLPS300ZX
16:50:31 05/14/19
I also brought this up (below)
FrozTTy
17:02:25 05/14/19
I was using a Specialty Z chip with dual pop and set up for
BannonZ
09:46:37 05/15/19
50psi cranking seems high.
MLPS300ZX
22:55:49 05/20/19
To back up a little for diagnostic purposes: When did the
SirpriZ
15:33:12 05/13/19
I have had this problem, getting progressively worse since
BannonZ
07:52:20 05/14/19
You've ruled out alot of potential issues: It isn't the
SirpriZ
18:35:43 05/14/19
Thank you for your help.
BannonZ
09:37:07 05/15/19
YW I don't think an internal engine issue would cause all
SirpriZ
15:09:32 05/15/19
What about the wiring that relocated PTU?
FrozTTy
09:34:04 05/14/19
When I put the new PTU in I replaced the harness with a
BannonZ
09:39:32 05/15/19
Silly question, but are you sure the gas is good? (n/m)
ZBOOSTT
14:13:38 05/15/19
I don't keep more than a quarter tank in the vehicle
BannonZ
14:44:09 05/15/19
Try one gallon of Toluene and that will clean the injectors
ZBOOSTT
18:59:51 05/20/19
Update
BannonZ
15:59:22 05/21/19
That's a shame. At least you'll have a definitive idea of -
SirpriZ
19:46:17 05/21/19
That's a bummer! Keep us posted! (n/m)
MLPS300ZX
02:54:25 05/22/19
Thanks guys, I will let you know.
BannonZ
07:26:51 05/22/19
GL let us know what's next (n/m)
FrozTTy
08:19:25 05/23/19
